I have used “grab” adhesive in the past, but had problem as they take a long time to set and the object need to be hold in place until they set.
So is there a fast setting “gap filling” adhesive? (A two part system when I put one part on each surface would be an option)
How big is the gap ? – Web Jan 26 '11 at 19:59
@web, The gap is 2 or 3 mm at most – Walker Jan 26 '11 at 22:21
What is the material the adhesive needs to work with? – John Gardeniers Jan 26 '11 at 23:25
@John, sorry fixing some plastic vents into a UPVC sofit – Walker Jan 27 '11 at 9:09
up vote 1 down vote accepted
This can depend on the size of the gap and the materials being joined. Two options come to mind that differ extremely.
First there is '5 minute' epoxy. Mix the two parts, hold for approx five minutes and its pretty set.
Second, for very small gaps, there is gap filling Cyanoacrylate glue. Then to get it to set fast you can use an accelerator that you spray on to it once its where you want. I doubt this is what you are looking for though. Its common to use this approach for filling voids in wood before finish sanding.
