Background: I know you're not supposed to dig a really wide hole for a fence post hole. But the previous owner of my home did not know that. He or she dug a really wide hole, filled it with a bunch of pavers and other junk, and poured a really big piece of concrete.
The fence post broke last month and I'm finally getting around to fixing it. So I dug out all the concrete and am using a tube to make it a little more manageable.
Question: What do I fill around the cylinder form? Dirt or gravel? I'm afraid that if I use dirt, it won't be compact enough and won't offer enough support. Or maybe I should use sand or something. I don't know.
Note: I was able to get about 8 inches deeper than the previous owner into really solid ground, so the form is stuck in there very tightly. Also, this will be for a metal fence post.
I ended up just putting the dirt back and tamping it down really hard with some random tools b/c I don't have a tamper. First I used the curved end of a large crowbar. Then I used a sledge hammer. I just filled in w/ dirt about 6 inches and then pounded all around for about 3 minutes. Then filled w/ dirt again. Not sure if this was "the" right way, but seems to be working really well. Very little wiggle room between the form and the ground.
That's the way it is done, what ever you have that will work, that gets it tight. I have a "special" 2X4 that I use. It is about 3 1/2 ft. long tapered to a handle on one end. been using it for years. When the space is to narrow for that I grab a piece of 1X – Jack May 11 '14 at 13:40
