Take the 2-minute tour ×
I know from my previous question that in most cases a cement board of some kind needs to be used. However, when the Kerdi membrane system is being used behind the tile, is it still necessary to use a cement backer board?
add comment
1 Answer
up vote 6 down vote accepted
Schluter says that behind the Kerdi membrane a solid backing needs to be used. They define a solid backing as :
  • gypsum wallboard
  • cementitious backer unit
  • fibercement underlayment
  • fiber-reinforced water-resistant
    gypsum
  • backerboard/underlayment
  • coated glass mat water-resistant gypsum
  • backerboard
  • portland cement mortar bed
  • concrete
  • masonry
Found this in their Shower System Installation Handbook here. Link : http://www.schluter.com/media/ShowerHandbook.pdf
Add a link to the source of this info to make this the perfect answer. –  auujay Jan 24 '11 at 21:28
@auujay : link added, thanks. –  Web Jan 24 '11 at 21:32
Perfect, thanks. –  tnorthcutt Jan 24 '11 at 21:44
add comment
