It seems whatever method I use I sometimes damage the wire and have to hope I have enough cable to have a 2nd try.
Is there a method that works 100% of the time for someone that is not doing it every day?
A possible duplicate has been pointed out, however it talks about 12/10 guage "Romex" rather then the normal 2.5mm twin and earth we have in the UK.
Are you removing the outer sheath, or stripping the inner wires? – Tester101 Jan 24 '11 at 13:08
Possible duplicate: diy.stackexchange.com/questions/3366/… – Tester101 Jan 24 '11 at 13:08
@Tester, I wish to do both, but removing the outer sheath is the harder bit. – Walker Jan 24 '11 at 13:11
This question has been asked before. Take a look at the answers to the question I linked to earlier, they should answer your question. – Tester101 Jan 24 '11 at 13:36
2.5mm T&E is very similar to 12/2 NM (non-metallic) cable. Romex is a brand name that has become synonymous with NM cable. – Niall C. Jan 24 '11 at 15:45
up vote 1 down vote accepted
There are tools which do the job for you. They will probably take a little adjustment when first used, but then they're fine. They are literally the easiest way to consistently strip mains cable.
Many years ago my father had a hand-held tool explicitly for stripping Australian 240V household wiring cable. It had two clamps, two blades and a two-part action. The first clamped the cable and made the cuts, the second separated the clamps, neatly stripping the end off the cable.
(I should add that I don't strip cable every day but I learnt how to use a small but very sharp pen knife to strip outer sheaths. A bit time-consuming, but I like doing it that way as it works on any sort of multi-core cable. And the trick to not nipping the conductor is to not cut quite all the way through the insulation: let the stripping effort break the last little bit.)
I love this little guy from ideal:
ideal lil ripper stripper
the tool is a hollow tube. there's a hooked blade centered in the middle so that when you push the cable through the tool, it splits the sheath without damaging the conductors. the v-groove at the end is for stripping the individual conductors.
it took almost no time for me to learn to strip the inner conductors without nicking. and now i can strip without even looking at the wire.
will it strip the outer sheaths as well? – Walker Jan 25 '11 at 15:41
Does anyone know if it is sold in the UK and if so what it is called in the UK? – Walker Jan 25 '11 at 15:51
i don't know where to get one in the UK, but i can confirm that it strips the outer sheath. – longneck Feb 2 '11 at 3:12
