How do you hang something on sheetrock if you have metal wall studs? The item is a very heavy shelf, so anchors aren't going to cut it.
marked as duplicate by Steven, Tester101 May 2 '14 at 10:16
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
How heavy is "very heavy"? – getterdun May 1 '14 at 1:50
Hardwood wine rack, probably 20-30lbs empty. Then add some expensive liquor and vintages... – Jonathan S. Fisher May 1 '14 at 15:06
Why not a wine rack that sits on the floor like a regular shelf? Liquid is heavy, and if your wine is nice enough to belong on a rack, it is expensive. Not worth the risk in my opinion – Snowman May 2 '14 at 3:57
I think you can use toggle bolts based on my experience with them and on the ratings given here: http://www.powers.com/pdfs/plastic/togglebolt.pdf.
looks like toggle bolts are the thing to use. Here's a vid including a load test where a guy hangs his body weight off of four of them youtube.com/watch?v=Wz8xYi_5pgg – Paul May 2 '14 at 5:20
Use heavy duty anchors spaced appropriately. If anchors will not do it, attaching to a stud will not work either and the object must be hung from a joist.
