I have an attic with a part where the floor was removed to bring light to the living room. I'd like to have my desk adjacent to that emptyness, but there's no space on the desk to place screens so I'd like to have them hanging above the emptyness.
Now it's pretty easy to find a desktop mount for 3 monitors that is attached to the desk (such as the Duronic DM553 Spring Triple), but I haven't found anything that would let me hang screens from the ceiling.
Furthermore, the mount should be screwed into the tilted wooden beam already present since the ceiling isn't plan, it is tilted ~30°.
My google-fu has failed me, any ideas?
EDIT: picture of the beamenter image description here
What size beam is this being attached to? Are you sure it can bear the load of three screens? – BigHomie Apr 30 '14 at 15:53
If three of these will work I'll draw it up as an answer. Wall, ceiling, it's all the same. Standard VESA mount as well, so your LCD must support that. It extends three ft from the 'wall', you didn't state the dropdown height you require. – BigHomie Apr 30 '14 at 15:55
@BigHomie The beam is massive, like 20x30cm – Baboon Apr 30 '14 at 15:56
@BigHomie What you linked doesn't work because the beam is tilted, attaching 3 of those to each face of the beam will result in non-aligned screens – Baboon Apr 30 '14 at 15:57
Can u post a pic of the beam? – BigHomie Apr 30 '14 at 16:04
Is mounting a triangle shaped hardwood block to reduce or eliminate the 30 degree angle out of the question? I would lag-bolt it to the beam and then mount the ceiling mount to that in the usual manner.
There are plenty of long extension monitor/TV ceiling mounts available which with the appropriate length, put the monitors at eye-level, but as you've found, 20 degrees is as much as the ceiling end will compensate for.
Also, several of the multi-monitor mounts use a chrome tube and the brackets are movable up and down the tube by a thumb screw arrangement. Nothing prevents you from changing the chrome tube out for your own custom length one that would extend from a drilled hole in the beam down to a floor or desk mounting block.
Having it supported on both ends also means you're not sporting a really expensive pendulum that bounces around in air currents or from the garbage truck rolling down the street.
That's a pretty good idea – Baboon Apr 30 '14 at 18:06
