I learned the hard way not to plank on floating laminate floor when the board my feet were on slid toward the wall.
I fixed it initially by just applying force in the other direction, but now it keeps on slipping out and I keep on slipping it back. It doesn't take much to move it anymore.
Can I fix it with wood glue or something stronger? It slides a good half an inch so there's plenty of space to gunk stuff in there. Otherwise, it is pretty close to the edge of the trim so I could pull that back and try wedging something in to stop it from moving.
gap
up vote 3 down vote accepted
What happened is that you broke off the MDF tab that was holding that plank in place. That's why it slides freely now; nothing's mechanically holding it in place anymore. Since the core is MDF, any kind of wood glue should be totally fine to fuse them together, and once glued, those two planks will probably be more strongly held to one another than the other ones that are only mechanically fastened. Once you apply the glue, tape the planks together with masking tape or blue painter's tape to prevent the glue from expanding and pushing them apart.
If you really wanna make sure it never comes loose again, you can get some of the wood wood glue that's specifically made for this use: Titebond!
+1 for including a picture :) – John Hunt Apr 30 '14 at 13:50
