I am planning on fitting this GK311-1224 ANSI Release to a door and using a simple switch and Arduino as triggers.
Are there any examples of a typical installation for a lock like this.
That lock is simple: give it 12 or 24 volts and it opens. You will want to wire it through a relay as an Arduino won't be able to drive it directly.
Sure, thanks... – conor Apr 29 '14 at 13:31
They have information over on the Arduino website for using a driver transistor to operate a relay (from 5v, low current to higher coil current/voltage) and properly diode bypass the relay coil to cancel out inductive kick. – Fiasco Labs Apr 29 '14 at 17:12
