This is a typical old-work junction box with integral NM cable clamps. They are each labeled with a tiny "N".
I had assumed this stood for NM and didn't give the labels a second thought. But then I removed this junction box from 1955:
Now the top clamps are all unlabeled and the bottom clamps alternate between "N" and "T". There is no perceptible difference between the "N" and "T" clamps except, when this particular box was installed, only the knockouts for the "N" clamps were used.
What do "N" and "T" stand for?
up vote 4 down vote accepted
From the UL White Book
Guide Information for Electrical Equipment The White Book 2012
Outlet Boxes and Fittings (QBPZ)
Metallic Outlet Boxes (QCIT)
CLAMPS
Boxes may or may not be provided with clamps. When clamps are provided, the carton is marked to indicate the type of wiring system or combination of systems for which they have been tested. The clamps are marked with the following letters or combinations thereof to indicate that they are suitable for use with armored cable ("A"): flexible metal conduit – "F," nonmetallic-sheathed cable – "N," or flexible tubing (loom) – "T." Clamps suitable for Type MC metal-clad cable are marked "MCI" for metal-clad interlocking armored cable, "MCI-A" for metal-clad interlocking armor ground cable, "MCS" for metal-clad continuous smooth-sheath cable, and "MCC" for metal-clad continuous corrugated-sheath cable. If suitable for all seven types, the clamp is marked "ALL." Clamps suitable for nonmetallic-sheathed cable are also suitable for multiconductor underground feeder and branch circuit cable where used in dry locations.
tl;dr
The letters indicate what type of wiring system the clamps should be used with.
  • A Armored cable
  • F Flexible metal conduit
  • N Nonmetallic-sheathed cable
  • T Flexible tubing
  • MCI Metal-clad interlocking armored cable
  • MCS Metal-clad continuous smooth-sheath cable
  • MCC Metal-clad continuous corrugated-sheath cable
  • ALL All
