I'm so pleased to find this diy.stackexchange.
I'm in the middle of replacing a small roof above an entry-way. It is an area of about 100 square feet (9.3 square meters). The top layer of shingles were completely worn out and came off easily. The bottom layer is stuck as if with glue to the sheathing. It seems as though instead of tar paper, the original roofer just spread actual tar instead of using tar paper (or the tar paper degraded and fused with everything around it). I was able to pry up the parts of this bottom layer that overlapped other shingles and get most of the nails out, but the stuck parts are better fastened to the sheathing than they are to themselves. In other words, they aren't coming off. I would like advice for how to proceed among these four options:
  1. Just put new shingles on top of what is left of the bottom layer of shingles
  2. lay out tar paper or felt over what is left of the bottom layer of shingles and then shingles.
  3. take the next several weeks to slowly scrape this tarry, shingle-shaped goop off my roof with, I don't know, a blow dryer and a cheese slicer?
  4. I guess pulling up the sheathing itself is an option, though it is beyond my skills, I think
Option #1 may be all you need, depending on how "lumpy" the surface is that you will be reroofing. A close up picture would be helpful. First thoughts are it will not be a problem if you use an architectural shingle with the extra tabs here and there. If it is a flat 3 tab shingle, it may show through a little if the surface is not flat. – Jack Apr 27 '14 at 3:35
Or if you want to help the next person who has to do this and it isn't that "lumpy", option #2 will make it easier to replace/repair in the future. As an aside, tar is easier to remove shingles from when it is really cold - it makes it brittle as opposed to gooey. – Comintern Apr 27 '14 at 17:21
I would try a heat gun and a two or three inch putty knife to get it off. It will probably be a slow process though. You can also use an old blade in a circular saw to cut grooves in the shingles nearly down to the roof and try chiseling them out with a 1" wood chisel. – getterdun May 2 '14 at 4:17
Here is what I ended up doing:
The entire roof had an ice and water shield that was sticking the shingles. This guy's write-up about his roof closely mirrors my situation in that it was south facing, low slope, and old.
After deciding to just lay shingles onto the remaining old shingles, I noticed that the sun warmed up the substance to the point where it was relatively easy to peel off the stuck shingles with the roofer's spade. So I got the old shingles off, put down felt and applied new roof. Thanks!
