Just had my DE filter replaced with a cartridge filter. The pipes going to the motor have three valves. Since the replacement I am losing water and can't remember which of the valves should be open and which should be closed. I believe one is for the vacuum system which I don't need, one is for the skimmer, and one for the main drain (can't remember which is which though). The two valves on the right regulate whether I am using the returns or the in-ground cleaning system. I have no problem with that.
Where do the two pipes on the right go? – wallyk Apr 25 '14 at 20:35
Those two go to the returns and the in ground cleaning system. – user21223 Apr 25 '14 at 20:57
Hi @user21223! It looks like you’ve accidentally created a couple of accounts. If you’d like to merge them (there are some advantages to doing so), the instructions are here. Welcome to the site! – Niall C. Apr 25 '14 at 21:01
Losing water? As in your water level is going down? That is not a problem with valve position. You've got a leak somewhere and a professional needs to address that.
