Tell me more ×
My kitchen ceiling joists are old and at varying heights. I'm trying to make it level, or at least flat, in preparation for drywall installation. Would you suggest installing strips of wood to the side of the joists or stacked to the bottom of the joists in order to even them out? Which is easier and faster? Which is stronger?
up vote 8 down vote accepted
The way we do it is to strap the joists perpendicular with 1X3 cheap strapping. Find the lowest point in the existing field of joists and that will be your level reference. We use a laser 360 degree level , but you can get by with a good 6 foot standard bubble level. Mark off the joists in 16" on center with an extra piece of strapping along each wall edge. Then set the first piece of strapping closest to the lowest point of the ceiling. Use simple shims under the strapping as you go to keep each piece of strapping level side to side and row or strapping to row of strapping. Secure the strapping with 4d or 6d ring nails to the joists. It will take a little time, but you should get the hang of it very quickly. The result should be a nice flat and level ceiling. I know this is a quick description, but I will be happy to give you more info and hints if you decide to use this method. BTW, this is definitely a 2 or 3 person job, and an air nailer will really help.
Cool technique. Thanks. We decided to use string measured to the floor to find the low point. Found that the joists were out of level by up to two inches. Would have been a lit of shimming. For this reason and to avoid some electrical wires running through the joists we ran 2x4s along the lenths of the joists to reach the low line (string to the rescue again). Thanks again. – jlpp Jan 23 '11 at 1:02
Wow, 2 inches is a 2X4 plus some. good luck. – shirlock homes Jan 23 '11 at 3:46
Actually needed some 2x6 too. – jlpp Jan 23 '11 at 18:24
FWIW, I've always heard this technique called 'furring strips' - en.wikipedia.org/wiki/Furring – Steve Fallows Jan 2 '12 at 15:15
Just saw an article on FineHomebuilding about leveling an old ceiling.
It sounds similar to what you ended up doing, except they used steel studs. They also give a good description of the installation process using a couple of guide strings to make sure everything ends up level.
