I came home from a 2 day trip and found cracks in my basement cement with water seeping into them. I noticed that when I ran the water it leaked more, any guess what the problem is?
where are the cracks in your basement? do you have pictures? what amount of water is coming in? – DMoore Apr 21 '14 at 14:25
More leakage when you run the water points firmly to leaking from sewer line. A leaking water line would, if anything leak less when the water was run (or more likely just not change) since it has water under pressure in it all times.
A sewer line does not have water in it until you run the water, so if the leak leaks more when the water is running, it's from a sewer line. Crude home test method is to toss some food coloring (or unsweetened drink mix, which can be a handy source of strong color) into the toilet and flush, and see if the leak color changes to match (it will generally be more dilute, so use a strong color mix.)
It sounds like you have a broken water line or sewage line somewhere. It could be in the slab or buried. Get a plumber that specializes in leak detection out there ASAP, and do not consume your water until you get the OK from them.
