I've moved into a house that has a Vaillant Solar system for helping heat the water. We had various issues that resulted in a Vaillant engineer visiting, who pointed out various problems, including a missing air separator.
The installer returned and added the air seperator, and I thought this would be the last of it :)
However; we've noticed that over time the pressure has been dropping; and rising again when hot (this rising makes me think it's not just a leak). When the last work was done, the pressure was 2-3 bar even when cold. The pressure relief valve is 6bar. Today, the pressure is 0.5bar at 30-40 degrees; but rises to around 2bar at 60-70 degrees.
After checking the manual again; I believe there are two issues; but I'd like to know the impact of them (whether they're the likely cause) before embarking on the mission that is trying to get Taylor Wimpey and/or the installers to fix stuff; because it's a world of pain, and nobody seems to have a clue about how this system works.
Here's a picture showing the system and where the air separator should be installed (page 28 of the manual):
Solar System
I've marked some things in red relating to the positioning of the air separator. The things that appear to be incorrect in my system are:
  1. The air separator is on the incoming hot fluid from the panels; which is shown here with a big X through it. This means the fluid going through the air separator is hotter than if it was on the pipe returning to the panels. Could this be the cause of pressure loss after hot days? (the system is supposed to shut off at high panel temperatures, so I would expect the fluid here to never be steam; but since the manual has a big X I'm wondering if there's a good reason for this?)
  2. The pipes into the coil in the water tank are crossed over - our incoming hot fluid goes into the bottom of the coil, not the top as shown here. I'm not entirely surprised by this, as the incoming pipes from the panels were crossed further up too causing another issue they had to fix. I'm not sure if this problem should really have an impact on anything (in fact, to me, this seems more sensible, pushing hot fluid up instead of down; but I known nothing about any of this stuff!)
So; in short:
  1. Are these problems enough that we should be fighting with Taylor Wimpey again?
  2. Are either these problems the likely cause of gradual pressure loss?
aaaaand hours after saying I didn't think there was a leak; I can hear what sounds like water dripping every 15 secs in the roof where the panels are :( – Danny Tuppeny Apr 18 '14 at 15:56
up vote 1 down vote accepted
Having the coil connections crossed over will decrease the efficiency of system. In the worst case it would be better to turn off the solar part of the system than have it run as installed!
In a heat exchanger like this, you want the outgoing fluid to be as cold as possible. For this reason you want it exiting the bottom of the tank where the water is colder.
In your case it might be so bad that hot water tank is heating the fluid above the input temperature and that the solar system is actually removing heat from the hot water tank. Even if it's not that bad it's definitely not good.
For more information look into counter-flow heat exchangers.
I don't know what would cause the pressure drop but I would agree with you that it appears your air separate was not installed as per the manual.
If you are experiencing large pressure changes as the temperature rises and falls, then the culprit could be the expansion vessel. This is designed to expand like a balloon, when the temperature of the system increases and thus reduces the increase in pressure that would otherwise result.
