Take the 2-minute tour ×
During the winter my valve that turns the water on and off broke so I replaced that, the valves are all going the right way, I turned the sprinklers on and everything works there is just low pressure. The water has been on the sprinklers for 3-4 days and there are no puddles arising so I assume there isn't a leak. I can't figure out what would be causing low pressure. Can someone please help?
Is the replacement valve the exact same design? Some valves are more restrictive than others. It could also be debris and/or dirt has gotten into the system. –  bcworkz Apr 5 '14 at 15:24
