The hearth in front of my newly retiled fireplace (which was described in a DIY blog) needs repainting to complete the job.
The hearth is made up of 6x6 ceramic tiles that have a well adhered coat of paint (or more likely several coats) over both the tiles and the grout. The surface is satin and has only a few small areas that have been worn through. There is no flaking.
I plan to wire brush any loose paint, sand lightly and wipe clean.
The Question: What type of paint is best to stand up to the scuffing of shoes, logs and fireplace tools, and to withstand a bit of heat (near the firebox edge) and the possible occasional flying cinder?
I like the hardness of enamels. Oil based trim paint or the newer water borne oils are quite tough.
Any benefit to Porch and Deck enamel? Or epoxy? Heat issues with any of them? – bib Apr 4 '14 at 17:59
Either should work. If the existing coat(s) show no sign of charring, you should be good. I would lean to an epoxy for both heat and wear, but the self cross linking resins in the water borne oils are tough. – HerrBag Apr 4 '14 at 18:34
I have used a top coat of Parks Super Glaze in high traffic areas. It is shiny but it finishes off really nice and the stuff is really hard after a day or two. There are other similar products as this but I have not used them recently.
Will this work on a vertical surface? – HerrBag Apr 4 '14 at 18:37
@HerrBag Yes. Just takes more time. Last time I used it, I did an end table and was too lazy to do all four sides separately. – DMoore Apr 4 '14 at 18:41
