In my house the drywall is contact with the concrete. This is putting lot of moisture in the drywall and eventually it will start to rot. What is the best solution in this case to isolate the wall with concrete moisture. Pictures attached.enter image description here
Drywall? looks like wood to me. – shirlock homes Mar 30 '14 at 11:16
@Shirlock Indeed Wood. The big question is how to prevent concrete moisture to go to wood preventing water damage – David Mar 30 '14 at 16:05
the idea will be to correct the drainage so the water flows away form the building. hard to really tell from the pic. – shirlock homes Mar 30 '14 at 16:17
Even if the drainage is proper, Will the leftover moisture not dangerous for the wall. Sorry i am a new homeowner and might be asking silly questions – David Mar 30 '14 at 16:35
up vote 1 down vote accepted
One way to get you siding off the concrete floor would be to trim it up 1/2 to 3/4 inch with a sonic crafter or something like that. You could then caulk the sill. I'd wait until it dries up a bit first.
Thanks for your input – David Mar 30 '14 at 16:34
The first issue is the moisture in the concrete - where is moisture coming from? Is the foundation sealed correctly? Even if you're dealing with drainage, you need to make sure that the basement has a proper incline (and make sure that the floor is sealed) directing the moisture towards the drain. This is a good place to start: http://www.everything-about-concrete.com/basement-floor-sealer.html
The second issue is that wood is resting on concrete. That has to change. Not just because it's kind of ugly, but also because it's going to be a repetitive source of problems associated with moisture. Exposed concrete in itself isn't terrible, but you shouldn't have any organics or drywall in direct contact with it. You could remove the wood and just have a concrete wall, or create a proper raised floor, or raise the wall with a metal separator. Painting a bare concrete wall isn't a terrible idea either - it may end up looking better than that wood, too.
I would remove the wood, seal the floor, and paint both the concrete wall and floor.
