We have a kenmore elite smartwash quiet pak 2 (723 wt-wt).
It starts the normal wash cycle and about 35 mins in, it will not go to a rinse cycle and it stops.Error F21 or Sud comes up. I can not proceed from there. since yesterday we have been having problems with it unlocking, it appears like it not fully draining. We cant drain wont open door tried following the operation instructions on the front tried resetting power still gets stuck at f21 / SUD wont drain
Has this always been a problem (since installing the washer), or has it just started (washer worked fine previously)? Where is the washer draining (washtub, standpipe, other)? Is the drain line extended beyond the factory supplied hose? – Tester101 Mar 26 '14 at 11:20
From my research, F21 is a slow drain error. Which means the washer is taking too long to drain. This points to either a problem with the discharge pump, or the plumbing of the drain. – Tester101 Mar 26 '14 at 11:23
ya we found the problem, it was a large chunk of cloth, an eye glasses cleaning cloth about 5" x 5" balled up and stuck in the drain pump exit hole, surprised something this large found its way down there – Chris McGrath Mar 26 '14 at 17:00
the washer is 6 years old – Chris McGrath Mar 26 '14 at 17:02
I am having the same problem right now! Where do I start?? – user34586 Mar 13 '15 at 13:54
up vote 0 down vote accepted
f21 - Long drain time - Pump was plugged
