I am looking for a highly transparent material that is available to buy in 0.1 mm thick film/sheets.
The only one I am aware of is PMMA (aka plexiglass) but I haven't been able to locate a supplier of such thin plates/film.
Do you have any other suggestions? (It does not have to be particularly strong, but highly transparent)
closed as off-topic by BMitch Mar 19 '14 at 14:36
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions seeking product or service recommendations are off-topic because they tend to become obsolete quickly. Instead, describe your situation and the specific problem you're trying to solve." – BMitch
If this question can be reworded to fit the rules in the help center, please edit the question.
-1 because I believe this is borderline with our "shopping advice" policy. See the meta discussion for more details about our product recommendation policy. – BMitch Mar 18 '14 at 16:52
0.1mm is impossibly thin for anything that's not just an adhesive glass covering or anything. You'll have a lot more options if you can tolerate greater thickness. – iLikeDirt Mar 18 '14 at 17:40
If you are good with "film" there are many options - mylar (polyester), whatever grocery store plastic wrap is, heat shrink window film (polyolefin, perhaps?)
If 50x75mm is sufficient size (you didn't specify), #1 microscope cover glass (thus - glass) is 0.13-0.17mm thick, and is available (at least) that large.
4 mil (0.004") is a pretty typical thickness for overhead transparencies, available at any office supply store. That's almost exactly 0.1mm.
