Tell me more ×
Other than looking up blue prints, which many homeowners may not have, are there ways to determine if a wall is load bearing?
Methods I can think of might include:
  • Going up in the attic to check if ceiling trusses run perpendicular to the wall
  • If the wall is an exterior wall
Any others?
24
1) Remove the wall, 2) If the house falls down, it was load bearing – Mark Henderson Aug 14 '10 at 5:24
up vote 11 down vote accepted
The methods you describe are probably the best, but if you can actually see the wall, a load bearing wall will generally have a double top plate but a non-load bearing wall usually won't.
in addition, the roof trusses will be sitting directly on top of this double top plate. – dave thieben Nov 11 '10 at 15:24
For many houses, a wall running down the middle of the house, parallel with the roof ridgeline is nearly always load bearing. You also may have easier access to the basement to check joist direction.
Unfortunately, the basement option is out. I've got a one story on a slab. – Doresoom Jul 21 '10 at 20:30
@Doresoom Mine too - I truly miss not having a basement or crawlspace. – Jared Harley Jul 29 '10 at 1:19
If the wall is above a basement or open crawlspace, you can look from below to see if it is on a bean or above a support post. If it is not, it still does not mean it is not load bearing, but it can help to understand the structure.
