Take the 2-minute tour ×
I had a wooden back door removed and replaced with a metal door following burglary twice. The workmen have left an inch gap between the wall and the door frame both internally and externally. What is the best material that can be used to fill this gap all around the frame? Can someone help please?
I would be glad to give an idea, but a picture of the conditions will help tailor an answer best suited for you –  Jack Mar 12 '14 at 23:23
If it's a hollow metal doorframe, it's generally intended to be filled with a cement mortar mixture, and I'm surprised if the job was considered complete without doing that. I've lived in a cheap apartment where they didn't bother to do that, and was burgled since the unfilled doorframe easily flexed far enough away from the door to clear the lock bolts when the thieves pried it.
I suppose it's also possible that it's simply the wrong size door/frame, in which case filling in with material similar to the wall (right - the title says bricks, so split bricks and mortar) might be appropriate - or getting the right sized door, but that's a step backwards.
That building was so poorly constructed that a few years after I moved out, the roof tore off in a thunderstorm (it was not a tornado.)
Flex the door frame I worked in an automotive repair shop housed in a metal frame building. One of the duties I had was to lock at night and set the alarm. One evening the door came open with a gentle tug on checking it was shut, I closed it and repeated the offense. Needless to say, I spent the next couple hours creating a jack bolt system and washer pack that firmly held the metal door frame in place against any prying. It would have easily opened with a screwdriver, and yes, the frame was actually a cement form that was supposed to be filled after installation to provide a solid structure –  Fiasco Labs May 31 '14 at 19:10
A 1 1/2" gap is pretty big and its possible that it was poorly fitted or poorly installed. I would have expected the workers to filled this and installed trim to finish the installation.
Generally speaking, you would fill this gap with an expanding foam meant for windows and doors (Great Stuff is a well known product for this).
But back to the large gap, the first thing I'd look at is if it's uniform around the door. Having a 3/4" gap on both sides wouldn't be as much of a problem, but if you have a large gap on one side with no gap on the other, my suggestion would be to move the door so that you have an even gap, and then proceed to fill the gap with expanding foam. You will want to add trim around the door after to finish it off, and then caulk the gaps where the trim meets the house and the door.
Be careful to get the "Door & Window - minimal expansion" expanding foam if you go this route; the normal stuff will pinch the door shut. My DIL's husband had the bright idea of using the "normal" foam, and the doors & windows all got bound up tight so they couldn't be opened. –  TDHofstetter Aug 29 '14 at 14:42
