Take the 2-minute tour ×
I have an existing, irregular river-stone fireplace and would like to fit a solid pine slab mantle to the surface.
I have considered scribing the top and bottom surfaces of the wood mantle, but I do not know how to account for the irregularities in the stones behind the mantle. I would like the mantle to sit reasonably flush to the stones. I am not interested in cutting or damaging the stones.
The mantle has a thickness of 4 inches and is 10 inches wide and 60 inches long.
Any thoughts or solutions would be appreciated.
Is this going to sit on a smaller stone mantle or fit perpendicular to the vertical stone flue with no stone support under it? –  shirlock homes Mar 9 '14 at 19:07
up vote 3 down vote accepted
To mount this mantle you will need to drill into the stone face!
The outline of the mantles' position should be taped to keep track of its placement. You will need to scribe the profile of the stone to the wood mantle. More on this if needed.
As long as the scribe marks are back cut severely, in essence, hollowing out (making it concave) the back edge where the mantle meets the stone, it should fit pretty well, save a little extra taken out here and there. You could use a small diameter disk sander on a drill with a VERY coarse grit paper on it. Self stick or screw on should work.
After you get it scribed where you want it to fit, find 2 or 3 suitable places to drill and epoxy steel pins into the stone face. Choose smaller stone to drill near, they will be better encapsulated in the mortar than larger stone so they have less of a tendency to fall out when drilled. 1/2" holes, 2 to 3" deep with 3/8" pins straight in with epoxy should do there. Please do dust out the drilled holes, the dust will not let the epoxy bond. Let it cure. Concrete epoxies only take about 15-45 minutes to get hard.
On the wood mantle, drill 3/4" holes, you can fill with the same epoxy, even if it is for concrete, the wood won't mind. Concrete epoxies offer two mixing tips, this will come in handy for the setting of the mantle.Here is an example
If you'd like to do a nicer fit to the stone (only you will know, of course, since it's out of sight) you can follow a fit&cut method - put chalk on the area of stones the mantel will cover, hold the mantle up to them (you'll probably want a temporary support so it always sits in the same place), take it down, cut away any wood with chalk on it, repeat. You can get as good of a fit as you care to with this method (not so picky, take big cuts; picky, take smaller ones.)
Even with a scribed top and bottom you'll need to do some of this to clear any stones that stick out further than the scribing.
