Tell me more ×
I want to put up a stone veneer surround, around a gas fireplace we're going to install. I've seen everything from using 1/2" plywood and a metal lath, to putting the tiles directly on drywall. I have everything apart so I want to do this the best way.
The tiles/stones I will be using are quite heavy as they are real stone and not "manufactured stone".
Items in play: - Weight - heavier tiles - heat - over and around a fireplace - Indoor
1 Answer
Drywall is out of the question due to weight, plywood might not give you the proper adhesion.
I would start with cement board, then attach the metal lath to that. After the metal lath is secure, you'll have to apply a scratch coat of a sand and cement mix before applying the stone.
Here is a good guide for applying stone veneer.
definitely start with a concrete board backer, avoid plywood in areas that may have heat issues, two reasons, fire danger and excessive expansion or contraction due to wide ranges of temp. – shirlock homes Jan 14 '11 at 7:30
Good point shirlock, I overlooked that he was installing it near a fireplace. – Tester101 Jan 14 '11 at 12:54
No problem tester, you are usually right on. – shirlock homes Jan 14 '11 at 19:53
