Sign up ×
I am trying to get a ceiling fan long screw out. The head is not stripped but the screw only turns (it started unscrewing) but it only came out a little. It is at a place that it does not come out. I have tried screwing it back in and then out but no luck. This particular screw is attached to the fan box in the wall and the attachment that holds the extention pole of the fan. Any ideas on what I can try?
A photo might be helpful. – Tester101 Mar 7 '14 at 23:04
Is it possible that it's a bolt with a nut, and now that it's loosened the nut and bolt spin together? If so, try applying downward force to the bolt as you turn it. So that the nut gets held in place as the bolt spins free. – Tester101 Mar 7 '14 at 23:07
It might be easier to cut off the head (assuming this releases the unit), disassemble the unit, and replace the screw. This assumes you cannot access the other end of the screw. Also, have you tried grabbing it with the vice grips and yanking down? – getterdun Mar 8 '14 at 4:20
Try (this may well be awkward, and will probably need a pair of locking pliers rather than a screwdriver - assuming it unscrewed far enough to get those on before it stopped) pulling down on the screw as you unscrew it. Whatever it's screwed into (a plate, or a nut) is now turning with it - you are trying to get the plate or nut to jam so that you can continue to unscrew it.
Thanks I will try that. Hopefully it works. I will let you know – THR Mar 7 '14 at 6:12
no luck with the locking pliers – THR Mar 7 '14 at 15:46
