This question already has an answer here:
i got a dryer that have a green netural cord but the cord couldn't fit in the outlet because it had 3 prong with a circle prong it may be 4 prong my old dryer has a three prong that fir in the outlet but doesn't had a ground wire can I use that 3 prong for my new dryer w/o a ground wire will that cause problems?
marked as duplicate by longneck, Ecnerwal, Tester101 Mar 4 '14 at 13:12
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
There's like 3 sentences in there but no periods. Please improve the grammar and punctuation of your post so that we can actually understand what you are asking. – longneck Mar 2 '14 at 3:45
When moving an electric dryer or range to a new (to it) dwelling, it is not unusual to have to replace the "cord" (pigtail) on the appliance. Look carefully at the outlet in the house and go to a hardware store, appliance store, or electrical supply store for a matching pigtail. These tend to run $20–30 at big box retailers and a little more at electrical suppliers.
If the outlet is unusual, it might be more expedient to replace it instead of tracking down a hard-to-find pigtail. Many do-it-yourselfers are uncomfortable working on 240 volt and/or high power outlets, so you might prefer to hire an electrician. However, since this is a DIY board, it isn't all that difficult once you understand the legal and electrical technicalities.
Old (pre-2000 or so) appliance outlets in North America used 3 wires: 2 hot wires and one neutral. Installations since then have added a 4th wire for ground. Your local code requirements may allow grandfathering existing three wire systems to remain in place for a simple outlet replacement. Other regions may require upgrading to 4 wire. Check out what your requirements are.
Replacing the outlet is fairly straightforward: shut off the circuit breaker. Check the outlet with a DMM or voltage tester to assure yourself it is really dead. Undo the retaining screws, pull out the outlet. This will require some strength due to the thick and stiff conductors, either 10, 8, or 6 gauge. Note carefully which wires are hot and which are neutral or ground. Unscrew the outlet's terminal screws and pull the wires out. If there is any discoloration or scorched insulation, trim the wire and re-strip.
Insert wires into the appropriate terminals on the new outlet and tighten securely. Ease the outlet back into the wall and screw into place. Turn on the breaker and check voltages are applied in the correct positions. Turn breaker off before inserting appliance pigtail and then back on once it is securely inserted.
+1 just for answering the question. – Edwin Mar 2 '14 at 8:25
The only appliances in question are electric dryers and household cooking appliances. Most all dryers and ranges are 120/240V, NOT just "240". This means they use and require a neutral conductor. Older circuits were allowed to omit the grounding conductor and used the neutral for both purposes. This is what's commonly referred to as a 3-wire cord. Newer circuits, and those in mobile homes and those fed from sub-panels, are 4-wire circuits. These have a separate dedicated grounding conductor. – Speedy Petey Mar 2 '14 at 12:53
Here is a good image of a 4-wire cord connected to a dryer. enter image description here
If you are going the other way, from a 4-wire to a 3-wire, then you MUST connect the internal green wire from the harness back to the chassis screw.
