I'm making a desk that measures 4000mm x 600mm x 32mm (width x length x thickness of desk surface) out of timber.
Im wondering how much space i should be putting in between supports. The desk will be mounted against the wall and the supports will run the length of the desk, and made of timber.
Thanks
I'm not clear on what you're asking. What do you mean "supports will run the length of the desk"? The material also matters: what kind of wood? Plywood, particle board, hardwood, softwood? If the wood is strong you could probably get away with a single support in the middle. (FYI, this desk is very shallow and may be unstable unless fastened to the wall.) – Henry Jackson Mar 2 '14 at 4:06
So, 157.48in x 23.622in x 1.25984in, that's less a desk and more a console table. – Dan D. Mar 2 '14 at 5:11
Since it's relatively narrow and against the wall, you could use some heavy duty L brackets and just mount it to the wall, then you don't need any supports to the floor. A proper bracket can easily support normal desk loads. – Johnny Mar 2 '14 at 17:16
