I want to level my concrete basement floor, but on one end it slants down over 1" (over a 3'x15' run).
Can I fill this area before using self-leveling compound, to save money, or what else could I use?
I have used Ardex K-15`to level floors. This product allows the addition of pea gravel for filling areas over 1/2" deep. use it with the pea gravel to fill the first 3/4" to 1/2" then use the Ardex K-15 without the pea gravel to top it off. I guess I got to throw in the obligatory remark, I do not own stock in Ardex, nor do I work for the company. This is a product that I have used before that works supremely when used, following the directions. There is a primer that is used with it.
Edit 2-26-14
When using the primer, lay out how far the Ardex will need to go with a pencil mark to get your floor leveled. read the directions on the primer container for dilution. Spread the primer at least 1-2ft OVER the marks, when feathering, as you will see this will come in handy. This stuff feathers out to zero. Be patient with this. It settles flat over a period of time, 5-10 minutes, you may notice a "ledge" forming at the edge if too much is used. That is where the extra primer comes in.
I forgot to add, you will need to layout two marks, one for the pea gravel added as well. DO NOT get this one too high, 1/8" to 1/4" low so the regular mix will flow over the gravel mix, and not get "hung up". Let it set for 2 hours, then move on with the next step with out the gravel.
Get a container that will allow 2 bags to be mixed at a time. I have gotten it from a big box store, the kind with the rope handles the are about 20 gals +/-. You need it this big to keep the mixing from slinging it out all over the place. Cover the floor where you mix about an 8X8' area aside from where you will pour. The drips from the mixer will be difficult to scrape off after a time
Do not worry about using their mixing paddle, there are paddles that will work. paddle1paddle2paddle3
The first one is my preferred one to use, it works with a little in the bucket or 10 inches deep. the third one is second, but it is a glorified whisk, no angles on the blades to "pick up" mix off the bottom. The middle one is an excellent mixer, but only effective when mixing large amounts. The top hoop needs to be covered for this one to work well.
More later if you need it.
Thanks Jack...fun with concrete. I'll try this. f – frank linn Feb 26 '14 at 12:18
I added a bit more detail, see answer.... – Jack Feb 26 '14 at 13:55
In short yes. Know that the concrete won't "stick" to your old concrete and over time it could slip a bit if there is a lot of horizontal force on it. You could fix that by drilling into old concrete and attaching a couple of pieces of rebar. For that area you would need maybe 3 rebar "L"s.
If you don't use rebar it isn't the end of the world though because the self-leveler isn't going to stick a whole lot better than the concrete. The reason why people use self-leveler is that it is easy and you know that you will have level sections. If you use concrete it will be hard to manage a level, smooth section.
Thanks. Could, or should I use Sakrete B1 to make up some of the 1"+ or is there another alternative? Since the self-level stuff cost $33 for 1/4" @50sq', it would be very expensive. Any ideas? f – frank linn Feb 25 '14 at 21:36
What flooring are you putting over this? – DMoore Feb 25 '14 at 21:37
