I'm a bit puzzled about what's behind the drywall in my high rise condo built 3 years back. When drilling into an interior room wall supposedly where a stud should be(found by a stud detector and yes I am using it properly), my drill goes through the wall with barely any resistance.
It's a fairly lengthy wall, about 10 feet connecting my living room to my bedroom. However, when I drill into the wall connecting to the neighbours, I feel a lot of resistance and definitely hitting a stud.
Could it simply be that the studs are paper thin and weren't meant to handle extra load besides the wall?
Even though you found the stud with your stud finder, you may have missed it. Even steel studs will offer a bit of resistance to drilling, and you should see some metal filings or twists following the bit out of the wall. You may have to try again with a very small bit 3/4 inch one way or the other to find the stud. Use your stud finder to give yourself a better idea what side of the original hole you should try. Of course, you can use the hole you already drilled by inserting a drywall anchor rated for the load you want to attach. I prefer the corkscrew type anchors to the expansion type.
There is a difference between the interior private walls and the common wall in condos. Common walls are always thicker, usually thicker sheetrock or two layers of 1/2 inch rock. This is for a longer fire time rating and soundproofing between units.
Thanks! You were right, I was off by a bit and just missed the stud. – user2308797 Feb 16 '14 at 22:17
Just an additional question, what's the typical load capable on a metal stud assuming I'm using a toggle bolt? For example, if I want to hang a mirror or tv that's 30lbs, do I need add plywood to the back? Or can I get away with toggle bolts on two studs? – user2308797 Feb 16 '14 at 22:24
the studs can handle a 30 pound load (15# per stud) very easily. No problem. Be sure to select the proper anchor for the load. There should be a load rating on the anchor packaging. – shirlock homes Feb 17 '14 at 11:44
