Some doors in my apartment are subject to seasonal changes, similar to what is described here. I made adjustments: shimmed some hinges, shaved off some material here and there with a planer, and the doors now close reasonably well. But the door moldings have quite a bit of seasonal play. There are gaps in the miter joints that show up in the winter and almost disappear in the summer.
I also installed two interior doors last summer. The way the doors open and close do not exhibit any seasonal variation, probably because I used screws to install door casings. I also filled the gaps behind the jambs with foam. The whole assembly is therefore very rigid. But the molding is again problematic. In a couple of places there are now gaps, very distracting because they appear as a black tear in the white paint.
What should I do to mitigate this? I am tempted to caulk the gaps and repaint, but I am not sure if this is a good idea: come summer time, the planks will expand and might pop out, or bend, or push other parts out of place. I also considered filling gaps with wood glue mixed with saw dust.
Is there a general recipe to avoid these type of problems in the first place?
up vote 2 down vote accepted
I am surprised this even happened at all. That is given 2 things have been met. The moisture content of the trim that you were using was low enough, 6-10%, and the wood used was a decent grade that did not contain "grain runoff".
The way to minimize the gaps that occur is to use biscuits in the joints.
The style of trim you chose, the traditional style that has been done for decades, if not centuries. The reason why it has worked all those years is that all the inside corners that are created by the various layers that make the detail. This hides the little wood movement that does happen. I would think since the trim used back in the day was not kiln dried, and carpenters had to find a way top hide the gaps or cracks created by seasonal movement.
If you did not caulk anywhere on your work, a clean line placed at the inside corners may be all you need, among starting with the things I mentioned at first.
Edit 2-14-2014
It is better you did not sand it anymore. The density of the knots compared to the rest of the wood, would have had the sander grind down the softer wood and left the knots more pronounced. Even with hand sanding, though not as bad. When the wood shrinks during the first year after install, which always happens, well at least most of the time, the knots also show themselves more. If you decide to leave the heads in, BEFORE you caulk, skim the whole face of the offending board like spackling a wall, then sand the whole face with a semi ridged sanding block and 80G sandpaper until you seen the knots just start to pop through, then stop with that grit then go to 120G and remove those 80 G scratches. Prime it and check your work, if it is good then caulk as recommended before. If it isn't, touch up with more lightweight wood filler and spot prime, then caulk.
Here is a sketch that will explain grain runoff to a degree. I found it is also called grain slope. That may have been the proper term all along. Where the grain slope would create a gap like that is in the long trim, the casing on the sides. Grain slope would actually make the piece shrink in length.
For trim I used knotty pine from my local home improvement store. I was inexperienced in that I did not anticipate the knots bleeding through. A coat of sealant fixed that just fine. Now it looks like I overlooked something else: moisture content and grain runoff. I have questions about both. How can I find out moisture content. Can you explain "grain runoff"? – user443854 Feb 14 '14 at 14:11
Not enough room in the comment box, so I edited the answer – Jack Feb 15 '14 at 1:41
Follow up on the moisture content. For the detail of trim you chose, moisture content is not that critical as long as the trim has not gotten wet, if so then it become a problem. I say this because, all wood bought from lumber stores has been kiln dried. When it comes out of the kiln it should be somewhere around 6% moisture content (MC). Sometimes less. After that the MC will increase in storage if there no humidity control, whether it be heat or AC. At the most it will increase to 10% unless it gets wet, then you are in trouble. Beyond that it will take a meter to test MC. – Jack Feb 15 '14 at 15:44
Jack's answer is completely correct. I will simplify the answer with some easy advice. Use some acrylic painter's caulk in a caulking gun, never use a silicon based product in this situation. When you cut the tip, only cut off enough to leave about an 1/8 inch opening at the tip. You want to push out a very thin bead of caulk that can be "pushed" into the offending gaps. Smooth the caulk with a wet finger or damp cloth. This will remove excess caulk and/or push it into the gaps at the same time. This type of caulk is water soluble so clean up is easy. Let the caulk dry as prescribed on the product tube before painting. Hint: I have found that Dap painter caulk dries and stays very white as opposed to Liquid Nails brand that seems to have a more yellowish color when cured. If you are going to paint, the cured color won't matter.
There are some other imperfections in the trim that I would like to fix. For example, I should have sanded it better. I was expecting that paint would hide that, but instead the paint does not do much to hide minor ripsaw marks, it in fact accentuates them. What should I do: sand in-place, caulk, then prime and paint? Or should I remove problematic parts of the trim and redo them using better grade wood? As @Jack implies, I used wood of insufficient quality. – user443854 Feb 14 '14 at 14:18
Replacing with a cleaner piece would be great, but you can sand it and repaint or maybe use lightweight Spackle that is sandable. Don't use caulk as it doesn't sand well and never really hardens up like Spackle. – shirlock homes Feb 14 '14 at 21:50
