My renter moved out an left a grimy mess. The filth on the stove top actually backed-up into the nooks and carnies of surface burner head, and seems almost impassible to clean.
Since the surface burner heads (figure 1) do not have an enamel coating, I was wondering, is it safe to stick them in the oven during the self clean cycle?
If so, would I be able to put the enameled surface burner caps (figure 2) and grates in as well?
Figure 1: Burner head designs make them hard to clean: Hard to clean burner head
Figure 2: Burner caps have a flat enameled surface and are generally easier to clean: enter image description here
Images sourced from amazon
Ugh! Some people. Too bad you can't put the whole range in for self clean! – bcworkz Feb 13 '14 at 19:05
up vote 1 down vote accepted
The self-clean temperature won't get high enough to melt the metal -- and the burner pieces are subject to pretty high heat anyway. I have cleaned aluminum and enameled parts in a self-clean cycle and the only time I have had problems is with large surface-area part (think a frying pan or something) -- in this case you might warp the metal by subjecting it to such high heat. I think the pieces you have will be just fin.
Tried it last night, both the burner head and the burner cap came out clean and undamaged!!!! I'm trying it with the burner grates now! :-) – virtualxtc Feb 16 '14 at 0:17
That's not paint, it's an enamel. I think that any of the flame-contact steel parts should be just fine (sometimes there are aluminum parts, which I'd feel less comfortable with). Magnets stick to steel not to aluminum, that's how you can tell.
The "burner head" is an aluminium alloy; the "burner cap" is steel with an enamel. The cap is a smooth surface and thus easier to clean than the head; hence my main concern is about the burner head. – virtualxtc Feb 14 '14 at 5:43
