What does it mean that my laptop screen size is 15.4 Inch or IPad screen size is 9.7 inch? Is it the width, length, diameter or surface?
Is the concept the same for the TVs, Monitors, tablets and cell phones? Wide screens and ...? Are there some standard length to width ratios for them?
closed as off-topic by Niall C. Feb 11 '14 at 2:01
  • This question does not appear to be about home improvement within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
This question appears to be off-topic because it is about consumer electronics – Niall C. Feb 11 '14 at 2:01
screens are measured on the diagonal. From corner to corner. – Fiasco Labs Feb 11 '14 at 3:40
up vote 2 down vote accepted
It is almost always diagonal measurement, from corner to opposite corner. Sometimes, they will refer to xx-class size (e. g. 45 inch diagonal-class, meaning "almost that size".
Conventional screens are generally 4:3 width-to-height ratio. Wide screens are generally 16:9, occasionally 16:10 or other ratios.
