I have security cameras (CCTV) and I'm trying to connect to my TV's that are using an outside antenna. I've been successful in getting a SV-2G splitter (5/1000 MHz) installed on the OTA feed prior to the Antenna Amplifier. The other leg of the splitter is where I connected the CCTV feed. This configuration yields good OTA channels and clarity, but the CCTV is very snowy. When I installed a Attenuator on the OTA feed (prior to the splitter) it cleaned up the CCTV feed, but have lost 30% of my OTA channels, probably due to the reduced signal input after the Attenuator. Is there a different type of splitter or Attenuator that I might try to regain the lost TV channels without affecting the quality of the CCTV picture?
Thanks
You should search out "channel modulators" this should help you achieve cctv on whatever channel you have available.
