Most of my walls consist of solid plaster over masonry, which makes electrical work difficult to say the least. I want to add some wiring to an existing wall in order to add light fixtures to a room which currently lacks them. Since there are no stud bays to run wires, I will need to cut channels in the plaster to run armored cable or conduit.
What are the best tools and techniques for accomplishing this?
how thick is the plaster? Is there any thing supporting the plaster such as lath or mesh? – mikes Feb 7 '14 at 14:48
How deep do wiring codes require the channel to be, and how must the cable be armored/protected? – DJohnM Feb 7 '14 at 17:43
@mikes the plaster is at least 3/4 of an inch thick based on some exploratory drilling. It appears to be applies directly on top of the concrete block; I'm not sure if there's any mesh or lathe. – friedo Feb 7 '14 at 21:09
up vote 4 down vote accepted
Channelling chisel on SDS drill.
For short runs a brick bolster works reasonably well (and produces much less dust)
Deeply scoring the plaster with a knife beforehand to define the edges of the channel may help to prevent large irregular chunks being removed.
