Artist recommends using 4" dry wall screws inserted at an angle to hang his art. This does not look sturdy. Any ideas ? The art is a large ceramic tic tac where 2" of the screw is inserted in one end for hanging purposes.
For starters, how much does it weigh? When you say drywall screws, do you mean regular drywall screws, or drywall anchors? Can you shift the artwork sideways a little bit so you can hit a stud? – Doresoom Feb 5 '14 at 20:31
I am not sure an artist is the best place to get advice on how to hang stuff on a wall. Most large art does not have a "hole" to hang things because this cause projections and tilting. – DMoore Feb 5 '14 at 21:00
Running this screw into a stud is the only way it will hold up at the angle needed to hold the artwork in place – Jack Feb 5 '14 at 21:47
Drywall itself is only 3/8 or 1/2 inch thick in most applications. Even with 2" sticking out, a 4" screw just sticks 1 1/2" into a hollow cavity. – bib Feb 5 '14 at 23:31
You are much better off using an anchor that is probably way over engineered for your artwork. For instance I would get a 150 lb anchor (or even better) like this. If you go straight into the stud you can really need a thicker screw for a lot of weight or it could sag. Problem I would foresee is the hole in artwork for screw not being big or deep enough for said screw.
I need to hang 14 of these pieces in a 7 x7 area, each weighs about 1 lb. – Chris Feb 5 '14 at 23:12
There are smaller self screw anchors but the example would work for that too - or its little brother. – DMoore Feb 5 '14 at 23:21
OP commented that each piece is only 1 lb. At this tiny weight, anything will do the job. If you can guarantee no one will touch them, any kind of nail or screw is perfectly fine. If you need something a little sturdier, use any kind of drywall anchor you can find. This will prevent movement and damage to the drywall if any of the pieces are bumped.
