Is there such thing as a soft tip screw driver that won't hurt painted screw tips?
up vote 2 down vote accepted
In researching your question I came across several jeweller sites that claim that with proper technique you should be able to remove the screws without damage.
However I found this unsatisfactory, so I dug deeper, and the answer is yes, there exists nylon bladed screw drivers
Not sure those will work - they seem designed for rimless glasses. I don't know that much about them, but it looks like they only come in incredibly small sizes... – Jaydles Feb 5 '14 at 16:58
@Jaydles the OP didn't specify a size; but if they had, I'm sure I could use google to find a nylon screwdriver for it. – virtualxtc Feb 5 '14 at 19:16
I put a bit of masking tape over the tip of the screwdriver to provide a bit of cushion and edge protection. I usually run into this when installing wall plates for switches and outlets. A standard screwdriver can scrape the paint off the screw pretty easily, but the tape works for me.
