I am dealing with recent flooding in my apartment. As you can imagine, I am doing repairs myself. The work is financed by my insurance company, which has been pretty good about it. There is just one point of disagreement, which is the subject of this post.
The walls in my apartment are not perfectly flat, and so when the baseboard is attached, there is always a gap, up to maybe 1/8". This gap is caulked and painted over for smooth finish. The point of disagreement is this: when the board is removed (I am replacing hardwood floor, so there is no getting around it), the caulk line is damaged, and needs to be scraped off and sanded smooth. Now when the board is attached, the gap needs to be re-caulked, and both the baseboard and the wall painted. I do not really see how one can avoid repainting the wall.
The insurance company is claiming that skilled workers can remove baseboard without damaging the wall, and therefore repainting the wall is not necessary.
Is this a reasonable claim? I do not really see how this can be done, but being a DIY'er and not a pro, I may be missing something.
They are going to damage your walls and they will need to be repainted. You can't expect NO issues. It could be as easy as 20 mins of touch up but there can be no expectation of not one nick on the wall. I would be surprised if just installing new hardwood didn't cause a few scratches. – DMoore Feb 4 '14 at 18:27
up vote 7 down vote accepted
I think there is a claim there, not well founded, but a claim. Of course the insurance companies are trying to keep the payout down as low as possible. There is always a chance for wall damage but extreme care in removal will lessen the chances.
Carefully score the caulk at the junction where the base and wall meet. Start with a light cut first, using a sharp blade, that cut alone may do most of what is needed. On the heavier areas of caulk it will take a repeated pass or passes. Try to hold the blade vertical enough to really get behind the base a little. There is a chance of leaving a mark from the knife at this angle so again, be careful. You can also wrap the part of the knife that is prone to hitting the wall with tape so it will not leave a mark. Drywall score
Next use a thin blade pry bar, together with a 4" wide drywall taping used as a shield to protect the drywall as the small pry bar is pushed or driven in. Do this ONLY at the studs! Watch carefully as the base is moving away, there is a chance that the caulk may still try to pull the drywall face off along with the paint. Recut where you see this occurring. After the base is away from the wall about 3/4" to 1' away change over to the larger bar to free the nails from the wall completely. Start this operation at a door where the trim meets the wall where possible, score that joint with a razor knife too.
The three illustrated are the small bars sold in a pack at your local hardware stores
Larger barenter image description here
This is the larger bar, maybe 16" long. Whenever you use a bar to pry material from a finish wall always do what you can to let the pressure on the wall be on the section hidden by the base. In other words, using the small bars, with the flat end in pry the top curved end away from the wall, the tip behind the base and the damage that occurs will not be seen. I know this is really elementary but it is for the next step I go this way. When the bar is turned around, or the curved end of the larger bar is used, with enough gap the "heel" of the bend will still be behind the base and against the wall to pull up on the bar and it will pull out any ornery nail that does not want to give up.
Edit
The bar on the left has a bend that is really not appropriate for the base removal. If you set the end behind the base to pull it off the extra bend will bind against the base you are trying to remove. The bar on the right, my favorite of all pry bars, will go behind the base and the heel, when the long end is pulled up on, the short end will drop behind the base low enough to engage the wall behind the base so it will not even need a protecting layer, putty knife or wood or what have you.
End edit
If the base is tight to the floor, that helps a bit. When you reinstall, preferably new base, you can either hold the base up a little higher, say 1/4" up, than the way it was originally installed. That hides the old caulk line therefore a better chance of looking like an original install after recaulk and painting. Shoe mold will cover the slight gap. Or install a taller base to do the same thing. Example, if your base is 3 1/4" tall, replace with the 4 1/4" tall version of the same.
excellent advice. I do have round base mold, so lifting the baseboard up 1/4" would not be a problem. This should indeed hide the original caulk line. – user443854 Feb 4 '14 at 16:05
