I have a brand new wall, taped and sanded smooth, ready to paint. What should I do next, prime it first and then nail the baseboard? Or the baseboard first, then prime?
I noticed that professionals working in my building install baseboards first, then caulk the gap and prime and paint the wall, then paint the baseboards.
closed as primarily opinion-based by Tester101 Feb 3 '14 at 15:32
Many good questions generate some degree of opinion based on expert experience, but answers to this question will tend to be almost entirely based on opinions, rather than facts, references, or specific expertise.If this question can be reworded to fit the rules in the help center, please edit the question.
I'd paint first. That way you won't have to cut in around the base molding. But that's just my opinion. There's no definitive answer to this question. Either way is fine. – Tester101 Feb 3 '14 at 15:32
Part 1: when I do this, I do the walls first. Then, I consider them done; that way I'm more careful with the baseboard. Then I paint the baseboard before installing because it's a lot easier that bending down and painting, plus I won't get paint above or below it. Then I nail the baseboard on, trying to squeeze the top flush with the wall. – getterdun Feb 4 '14 at 1:40
Part 2: Normally though there is still a gap between the top of the baseboard and the wall. I caulk the gap with the tip cut just big enough to fill the gap, making sure the caulk goes only in the gap. Then I wipe it with my finger until its relatively flat, and the caulk on the wall is level with the top of the trim. I fill the nail holes with either caulk or window putty or spackling depending on whats handy. After the caulk dries, I carefully paint the top edge of the trim: its relatively easy to paint this edge without getting any on the wall. I also touch up the caulked nail holes. – getterdun Feb 4 '14 at 1:42
