I recently had a security system installed which also included a replacement thermostat. Should I just throw this old one in the trash?
closed as primarily opinion-based by Steven, Niall C. Feb 3 '14 at 2:44
Many good questions generate some degree of opinion based on expert experience, but answers to this question will tend to be almost entirely based on opinions, rather than facts, references, or specific expertise.If this question can be reworded to fit the rules in the help center, please edit the question.
Cheap digital thermostats can be had for under $20 if you ever needed one again, so it's your call to decide if it's worth hanging on to. Personally I'd get rid of it. FYI, Best Buy takes a ton of electronics and appliances for free recycling. I bet they would take a thermostat. – Henry Jackson Feb 3 '14 at 0:52
Its not like it has a mercury switch to worry about. Send those to me ;-). – HerrBag Feb 3 '14 at 2:33
up vote 1 down vote accepted
If your security system is monitored for a monthly fee I would save it. There is the possibility that it won't function if the service is terminated. If a year from now you decide you no longer want the service you may be in need of a new thermostat. Although it appears to be relatively new verify it doesn't contain mercury, even if it doesn't try to recycle it when you do throw it out.
