Take the 2-minute tour ×
I have an existing metal fence post, set in concrete, in which I'd like to drill a new hole in that post.
Normally, I would use a drill press to drill into a curved surface like this. Since the post is already set in concrete, this is not a viable option.
Is there some sort of guide jig or other tool or process to make this task easier? I'm having quite a time drilling even a small pilot hole.
add comment
up vote 5 down vote accepted
The punch suggested by SpectralGhost is a good idea.
If that doesn't work, you can make a jig with three pieces of 2x4.
pipe jig
Screw the pieces together and drill a pilot hole for the drill bit (the dotted line) using the same size bit you intend to use on the pipe.
this seems like a great idea. i'll be trying this asap. thanks! –  nullrevolution Jan 31 at 19:15
add comment
I would use a punch to make a small dent in the pole so my drill bit wouldn't slip.
Center punch with a sharp 60 degree tip to guide the drill bit, you want a nice conical guide for the bit. Use a small drill to drill a pilot hole as it will be less likely to jump out of the center punch divot, finish out with full size drill bit. Many's the annoying non-flat surface I've had to do, it's all in the start. Make sure the centerpunch has a nice sharp, hardened tip. The usual failure with this method is to use an 20 year old punch that now has a ball tip due to lack of maintenance. –  Fiasco Labs Jan 31 at 18:34
i should have mentioned in the question that i've had trouble with the punch method. and i suspect that Fiasco Labs is correct: my punch is far from new and is not terribly sharp. +1 for the thoughts. –  nullrevolution Jan 31 at 19:10
I would add, start at a slow speed and just enough pressure to keep the drill bit cutting. –  mikes Jan 31 at 20:09
add comment
