My bed has a nut and bolt that are recessed into a piece of wood.
The only tool I have that fits it is the tiny toy spanner that came with the bed.
The spanner does not grip the nut tightly enough to be able to turn it.
But a larger adjustable spanner/pair of grips does not fit in the hole.
How could I tighten this nut?
Update: The toy spanner did work up to a point, but now it just slips off the nut every time, as if it's too loose.
recessed nut and bolt tiny toy spanner spanner on bolt
What does the head of the bolt look like? Can you just hold this nut while you turn the bolt from the head? A closed end wrench would fit over that nut too I you have a set of those around. – dslake Jan 24 '14 at 9:03
it's possible that the hole is only to hold the nut while you turn the bolt with – ratchet freak Jan 24 '14 at 11:20
Your third photo seems to show the wrench gripping the bolt. So, I don't get what the problem is. You do realize that you have to flip the wrench over after you turn the nut and the wrench hits the wood. If the problem is that you cannot get enough torque on the wrench, look around for a piece of pipe that will slip over the other end of the wrench. That'll give you more torque. – getterdun Jan 25 '14 at 3:54
@getterdun It's not about torque, the toy wrench slips off the nut. – Will Sheppard Jan 25 '14 at 7:59
Will, I still don't understand what you mean by "slips". Do you mean the wrench is the wrong size? Or, do you mean the nut is rounded? For the former what to do is obvious. For the latter I'd use needle nose vice-grip pliers to turn it. – getterdun Jan 27 '14 at 6:13
You can often get a box-type ratchet wrench around those recessed nuts ratchet wrench
These often come in sets. They are a bit pricey but have many uses. While you can also use a standard box wrench (a closed loop without the ratchet), in tight places, placing the wrench, advancing it a fraction of a turn, freeing the wrench, resetting it and turning again can get annoying.
But even a standard open end wrench (like the U shaped end of the wrench above) would give you more grip than the toy wrench provided.
 Links and images are for illustration only and are not endorsements
Don't underestimate what that little wrench will do, or how much torque you need to hold the bed rails together. With the lock washer, it only needs to be compressed, plus maybe another half turn at the most. The force created by the threads drawing through the nut create an incredible amount of pressure on the joining faces.
The included wrench has 2 distinct ends, one has the legs of the wrench equal lengths more or less, the other end has a shorter leg on one side. Because of the shape of the wrenches, I will assume there is little or no space to get a box end wrench around it, if there is any room behind it, then a box end wrench can be ground down enough to fit around it. A rail bolt wrench may work too, they are made to fit into even a deeper, hole. They are used for handrail assembly.enter image description here
Back to the offered wrench, the one end with the short leg, in my opinion is the workhorse, the short side is always on the leading side of the turn, as in if you are turning to the right, or clockwise, the short side is on the right side. That side is shorter so it does not bottom out as quickly in the shallow hole the captured nut is in. The wrench with the equal lengths are for the nut when it is in the midway point, where the nut is being turned where the legs of the wrench will still clear the bottom of the hole. As soon as one side of the wrench touches the bottom of the drilled hole, turn it around, and use the end with the short leg to complete the turn, so to speak, then swap ends again, turn that a little, then change ends of the wrench, and repeat.
You may have tried these techniques already, but it wasn't stated in your question to what extent you tried to work with the wrench. The picture of the wrench only shows a little distortion on the short leg of the one end that would occur if the wrench is turned the wrong way. Even though there a slight distortion, having the proper orientation of the wrench to the nut, that won't matter.
+1 love the rail bolt wrench (have used it on at least two projects) but the nut size may be a problem. OP's looks bigger. – bib Jan 24 '14 at 17:24
I think it is a 1/2", there is always the box end wrench that has been ground on. I am pretty sure there is not much room if any behind the nut to the wood/particleboard – Jack Jan 25 '14 at 0:50
@Jack it's just really difficult to even turn these nuts at all. Mostly the included wrench will not even grip, as if it's too big. Then randomly on the 10th try it will catch and I'll be able to turn the nut a tiny bit. But even when I've screwed it as hard as possible, the bed is still creaking like hell at those joints, as if it's still too loose and shifting around. – Will Sheppard Jan 29 '14 at 7:53
@Jack thank you for your detailed instructions! – Will Sheppard Jan 29 '14 at 8:21
