I recently bought "dimmable LED lights" without knowing exactly what this means. I did some research, and now I get it. A dimmer is required to regulate the intensity of the lights, for which I don't have a need.
Is there any problem with using dimmable LEDs without a dimmer? Will they work normally? I don't actually want to dim them, so I am not sure if I need a dimmer or not.
up vote 6 down vote accepted
No, there won't be any problem. I've been using four "dimmable" BR30 LED floodlights in my recessed kitchen cans for some time now, and I don't have a dimmer. They just start at full brightness and stay there. You don't need to use these with a dimmer if you don't want to. No performance or longevity problems.
Dimmable simply means a claim that they are compatible with a dimmer. When used without a dimmer they will be at full brightness.
