In my pantry cabinet, the holes for the plastic brackets has gotten too large and they do not hold. The cabinets are made out of particle board. Does anyone have any suggestions?
Can you show a closeup well focused picture of the damaged hole area and a picture of the plastic bracket? – Michael Karas Jan 18 '14 at 19:37
The metric (4 or 5mm) holes can be redrilled to hold the 1/4" shelf spoons. If that does not do it, there are metal sockets for the 1/4" spoons that take a slightly larger hole, then they can be driven into place to hold the larger spoon. If the spoons or clips already have a 1/4" hole, then you may be better off retro fitting a shelf track system. Third pic.
Instead of trying to drive nails in a tight space, use 4ga X3/4" screws instead, the cabinet will thank you for it.
enter image description here enter image description here enter image description here
The picture size is grossly out of proportion, buit the first pic is the socket that holds the spoon which is the second pic. The socket looks more like a bucket, that will hold 10 of those spoons..
You could also drill out a much larger hole (3/4" seems good to me) and glue in a wooden (non-particle board) plug. After the glue is dried, drill the proper size hole in the plug.
I think toggle bolts...they are made to grab behind board (wall board etc.) that has too big holes.
