It is strange, the bathroom fan is buzzing and humming when I first turn it on. After a few minutes, it starts up normally.
Why is it doing this?
up vote 3 down vote accepted
Sticky old oil in the bearings. After buzzing (and probably turning very slowly) for a while, the motor heats up enough for the oil to liquify, and then it runs normally.
Try fresh oil if the bearings have a place to apply oil, or consider a new fan. This is a common problem with old fans.
Last night it stopped and never run again, is it still repairable? – Love Jan 17 '14 at 13:45
Sounds like it's time for a new one. You might be able to replace the motor, but this usually only makes economic sense when you can't just replace the whole fan for some reason. – Ecnerwal Jan 18 '14 at 1:47
