How do I hide screws on the side of a kitchen cabinet wall that has slightly countersunk screws? I will be painting my cabinets black.
kitchen cabinets before and after with countersunk screws
You can use wood filler if you're painting the cabinets. Use a putty knife to apply, and then sand even after it dries.
Alternatively, if you're going to stain the cabinets, you can use a plug cutter that matches the countersink diameter. Using matching scrap wood, cut a plug that has a similar grain pattern, and lightly tap it in the hole after applying a thin layer of wood glue. When it dries, you can use a chisel to cut it flush or nearly flush, and then finish up with sandpaper. Then you're ready to stain!
If I remember correctly, this 5/16" diameter plug cutter works well with a #8 countersink hole. (You may want to check, it's been a while since I used that combination on a project.)
veneer would also work, though may be overkill if you're just painting the cabinet. – Tester101 Jan 13 '14 at 17:23
I'm not a DIY genius, but I'd go with "filler".
We're looking for long answers that provide some explanation and context. Don't just give a one-line answer; explain why your answer is right, ideally with citations. Answers that don't include explanations may be removed.
This would make sense as a comment, but still doesn't add much info. Some people might make a comment to @Doresoom such as +1 for the filler suggestion and upvote it to show your approval. – bib Jan 13 '14 at 20:09
I know... but its like asking "how do I fold paper" – Digital Lightcraft Jan 14 '14 at 9:14
@DarkcatStudios, The question may have seemed simple enough to you, but trivializing the OP's question doesn't help them out any. It wasn't a stupid question, just an easy one for most people who have a little experience with home repair/woodworking. Isn't that the whole point of this site? To impart our DIY knowledge/experience to others? – Doresoom Jan 14 '14 at 17:04
