I just brought two small Ethernet-type cards, so I could start a project to control the single radiator in my student accommodation over the internet. (#EngineeringStudent)
Now, the when I came back from my holidays, the valve jammed and it was freezing with 18 degrees (I turned it down manually while I was gone). So....
Are there any obvious problems of getting a motor (servo) to change the radiator setting say, every 6 or 12 hours, automatically according to the temprature? With this previous history, do I run the risk jamming the valve again? It's just a standard thermostat control which I intended to attach the motor to.
Thanks, Manfred :)
Picture? The style matters. – Bryce Jan 11 '14 at 19:18
up vote 1 down vote accepted
Those are inexpensive mechanical controls. There's no reason they can't be rotated every few hours. Doing so, however, is mechanically challenging. Good luck. Be sure to decouple your rotor (with a belt or gasket) so it does not place undue mechanical stress on the knob.
