I'm becoming more frustrated than I'd like to admit trying to wire this button up, and I often find the easier method it was designed for when I'm having this much trouble.
Sorry for the poor man's macro; there is a clickthrough to the product's datasheet.
If this question is off-topic for DIY.SE and on-topic for another, by all means flag for migration. I'm following a past suggestion from this question over at EE.SE.
It should go without saying that I'm asking this before I solder the wires onto the leads. – Sean Allred Jan 9 '14 at 7:35
I don't understand what the question is. The type of leads are called solder terminals or solder lugs. Is there a diagram showing how the leads are connected as the button is operated? That should show the proper way to connect to it for your needs. – wallyk Jan 9 '14 at 7:57
@wallyk No, no diagram unfortunately—no documentation whatsoever save the datasheet—but that did give me an idea. Do you think these are mean to be through-holes of sorts? Where I would stick in the wire and then fill the hole with solder? – Sean Allred Jan 9 '14 at 8:24
I'm not sure the EE people understand the definitions of "home" in home improvement and "hobby" in hobby projects. – BMitch Jan 9 '14 at 14:13
@SeanAllred it's in a gray area, but others from the community don't seem to have a problem with it, so no mod hammer from me. I did want to be sure that others looking at this question didn't use it as an example of a good on topic question. – BMitch Jan 9 '14 at 20:24
up vote 4 down vote accepted
Making connections
You can use heatshrink tubing to insulate the connection and prevent the wires shorting together.
Slide a section on, out of the way, before attaching the wire, solder the wire, slide the tube over the exposed wire and heat it to shrink it.
Which connections
You don't say what this "button" is for. I don't know of a function for a push-button operating a switch with five terminals.
You can usually use the continuity function of a multimeter to work out which terminals are connected to which before, whilst and after pressing the button. From this you can work out how to wire up the connections to whatever it controls.
If you were curious, it's a SPDT momentary with an integrated LED, and it will be mounted into an enclosure to control on/off. Thanks for the heatshrink reminder—I definitely would have forgotten that! – Sean Allred Jan 9 '14 at 12:05
FYI, they are called Solder lugs – Jason Jan 9 '14 at 17:45
You might be able to use an appropriately sized female disconnect crimp terminal.
Female Disconnect
Simply insert the wire into the insulated (blue) end, crimp the wire into a female disconnect using a crimping tool, then fit the terminal onto the appropriate pin.
Fully insulated, and fully insulated 90 degree female disconnects are also available.
Fully insulated female disconnectFully insulated 90 degree female disconnect
It appears that this might fit it (.110"). Are you suggesting putting the blue end down onto the button, or the other way around? – Sean Allred Jan 9 '14 at 10:42
You insert the wire into the blue (insulated) end and crimp the connector onto the wire. The uninsulated end would go onto the connector on the switch. – John Jan 9 '14 at 13:30
Those are not crimp terminals and not structural suited for it. – Jason Jan 9 '14 at 17:39
