I recently installed ceiling fans along with a remote-control module to adjust speed. As a result, I do not need or want the pull-chains to control the speed of the fan or turn on/off the light. Removing the switch itself is a trivial electrical problem of cutting the wires and tying them together, but I'm left with an ugly hole in the side of the fan.
Is there something I can use to nicely cap the hole? The fans are polished brass if that matters.
