My Kill A Watt P4400 by P3 International shows 3 watts electricity usage if anything is plugged in. Do things plugged in, regardless of whether they are ON or OFF, really use a minimum of 3 watts or is it an inaccuracy on the part of the Kill A Watt?
Pardon me if I misuse terminology; I'm not too familiar with electrical terminology, only electronics.
Sounds like an inaccuracy in your meter. Mine reads zero watts with nothing plugged in (or something plugged in but powered off with a hard power switch). Some devices (like TV's, DVD players, etc, anything with a "soft" power switch or remote control) will use some power even while they appear to be turned off. – Johnny Jan 4 '14 at 21:28
up vote 2 down vote accepted
To test, plug a non-electronic lamp in, and turn the lamp off. Your P3 should show zero watts, or it is clearly defective.
Many electronic devices have "parasitic" or "phantom" or "vampire" power usage: I have a toothbrush charger that shows about four watts, 24 hours a day, 7 days a week. There's a radio that when off shows about ten watts. And several Apple chargers that show a big zero when charging is done, due to better technology.
Note with the P3 you'll have to measure over a period of a few days, to accurately measure devices that draw less than one watt.
Here's an example study on the topic: http://digitalcommons.calpoly.edu/cgi/viewcontent.cgi?article=1046&context=eesp See also: How do you determine how much electricity is used by a device?
It certainly is an inaccuracy. In Europe, since 2013, home appliances may draw at most 0.5 Watt in their stand-by mode, and many draw less. And it’s not just stand-by – if for example a phone charger rated at 1W output would draw over 1.5W, I’d return it as defective.
