I want to install steps to my basement. I need to saw through a hardwood floor. Is there anything specifically I need to do to the hardwood?
If you are going to salvage your floor, that is, try to set your new stairs with its landing nosing to meet the original floor, you need to make a rough cut with a carbide saw blade say about a 24 tooth blade. This cut is to be made smaller than you need at first to find the limits the stair will fit. After the area is checked for how the framing is in the area and the place is determined where the nosing will stop against the original floor, that cut is made with a new carbide tipped blade, if the other blade found nails. If a nail is found with the new blade, cut through it, then change to a new blade and continue cutting until another nail is found, then replace the blade again.
If you are going to do a new floor "tie in" and flooring is to be reset anyway, then the final cut does not need to be this critical. If you are getting floor installers to do the tie in, they will cut back, tooth in, all that for you. Just make sure the landing nose is securely set at the stair.
This is a start, other will factors determine how to cut the floor to make the install of stairs simpler, that would take photos of the area in question. As in, is it a stair well closed on the sides, or a open stair well with the new stairs exposed to the room to start?
Not really. If feeling overly fussy you can knife-cut just to the outside of where you'll saw cut, or tape over the cut area (both attempting to reduce splintering) but if you use a good sharp sawblade and don't jam it, you should be able to just dive in and cut it. The structures below are of more concern (wiring, plumbing, and holding up the joists.)
Use a sharp one, but don't use your nicest sawblade - you're probably going to hit some nails.
Be aware that the floor may be held down with hardened nails that may destroy the saw blade. – mikes Dec 27 '13 at 0:24
Another thing to reduce splintering is to use a high tooth-count blade, the same as when cutting hardwood to install it. A blade made for ripping plywood is going to ruin your day. – Brian Roach Dec 27 '13 at 7:11
