So we had our roof replaced in 2007 from a ribbed metal roof to a comp roof. We also live in Washington State in a gambrel roofed home with no duct work and about a 4' by 12' attic.
During the tear off, the metal roofing and stringers were torn off. Then sheathing was layed down, followed by paper, ice dam and shingles. Beautiful roof right!
Fast forward six months later, I was fetching something out of our small attic and there was standing water and mold under the visqueen. It was horrid and I was less than thrilled. So I called the roofer and he sent a dude out and he yoked out the bad stuff, painted the entire attic with Kilz and replaced the insulation, A few weeks later a few of them came out and cut in a ridge vent. Cakes and rainbows right?
Now, there are dark areas showing up on the ceiling where the rafters are. The only thing I can think of is that the rafters are getting wet.
So my question is what are the chances that the rest of the insulation is in as bad of shape as what I saw in the attic? Am i looking at a huge mold problem?
Also, before the sheathing was put down, shouldn't the stringers have been replaced as well? Without the stringers, wouldn't it be a giant dead space with no circulation? Looking from the inside, the layers are drywall, visqueen, insulation, sheathing and roofing. I would assume there is no air circulation.
There are a few roof vents but I'm not sure how effective those are either.
Any suggestions? Should I call him up after six years? Is this an insurance thing? Should I track down a mold inspector?
Any help or guidance would be greatly appreciated.
R, Zac
up vote 1 down vote accepted
Any moisture issues related to the standing water incident would have manifested itself long before now. Whatever the current issue is, it's unrelated to the previous issue. In that time, it is possible a new leak developed. It's also possible the dark areas are related to interior humidity and unrelated to the roof. In cold weather, the ceiling surface under rafters is measurably cooler than the nearby portion under insulation alone. This can cause condensation only under the rafters. As you know, condensation can lead to mold.
Can you tell if the darkening is due to actual mold? The damp surface can attract dirt that darkens the area even though no mold is growing. Even though the dirt can stain, attempting to clean an area with plain soap and water would yield a very different result than if mold is actively growing.
If mold is actively growing, it is time to consult with a mold professional. They will determine the cause, mitigate the mold, and suggest how to prevent it from happening again. If you want to investigate further before going that route, the only reliable way to determine if the rafters are getting wet is direct inspection.
Cut a small inspection hole where you think it's the worst. If it's wet up there, a lot more ceiling is coming off, so don't bother patching the hole. The roof is leaking. It needs to be repaired and all wet drywall and insulation needs to be replaced. If it's all dry, breathe a sigh of relief. The need to patch the hole is much less than it could have been. Be sure to adequately seal the damaged vapor barrier.
If the rafters are dry, the only thing you can do to reduce condensation on the ceiling is reduce the overall humidity of the house. First try selective ventilation and lifestyle adjustments. Consider bumping the thermostat up a bit. If that's not enough, look into continuous ventilation through an air to air heat exchanger.
A far as replacing stringers, that cannot be done with comp roofing unless a full cold roof is installed. It is normal practice for concealed structural spaces filled with insulation to not be ventilated. It sounds like the roofers followed conventional building practice.
Wow! First, thank you very much for your time and effort. I think you have more or less calmed my nerves and squashed the idea that my home is rotting away. Comming from a non-roofers point-of-view it just seemed wonky to not replace the stringers. Although I climbed up there as they were doing the tear off and the insulation looked fine, it just seemed counter intuitive to cut air flow off to the roof. I would also like to put in a conventional central air unit but we have no duct work. We did however decide on going with a ductless system we can feed through our small attic. – photopusher Dec 27 '13 at 22:15
That is why I was originally concerned. There is less then 10in of material between the paint on the walls and the shingles. I'm assuming thats why there were stringers put down in the first place, so the roof was able to breathe. And after seeing the monster growing in the attic, it really bothered me. The good thing is that there is no sign of moisture in the attic anymore. Like you stated above, I'm leaning more toward dirt just being attracted to the cooler rafters. We also live in eastern washington and we are fortunate enough to have four seasons so it gets plenty hot in the spring – photopusher Dec 27 '13 at 22:24
and summer to dry out any moisture. Do you think moisture along the rafters could be an eventual issue? And we heat in the winter solely by wood stove. I imagine that could be a significant contributing factor to the dark rafter lines. Thank you again very much for your help. – photopusher Dec 27 '13 at 22:27
You're most welcome. A wood stove explains it all. Soot is attracted to the slightest increase in surface humidity, even with no moisture being evident. Even the tightest stove installation emits soot during lighting and refueling procedures. It all adds up over time. Other than being unsightly and somewhat staining, there's nothing to worry about. Even though 10 in between your comfy home and frigid weather seems like very little, it's considered marginally adequate in most climates. You lose far more heat through your windows. – bcworkz Dec 27 '13 at 22:46
